DHCP is a client-server protocol that manages IPv4 and IPv6 address assignment to network resources and mobile devices. Central to the DHCP IP address management process is the DHCP server that dynamically assigns IP addresses and related configuration information, such as gateways and subnet masks to the DHCP client. WiNG devices (controllers and access points) have built-in DHCP servers that can be enabled to manage IP address assignment.
DHCP servers assign IP addresses from a pre-configured set of address pools. DHCP assigned IP addresses come with a specified lease time and have to be renewed before expiry. The DHCP server policy defines the IP address pool and
The DHCP server policy ensures all IP addresses are unique and no IP address is assigned to a second client while the first client's assignment is valid. Configure the DHCP server policy and apply to the controller or access point to enable the device as the onboard DHCP server.
You can use external DHCP servers for dynamic IP address assignment. If using an external DHCP server, configure infrastructure controllers/access points to relay DHCP requests to the external DHCP server.Use the the following command to navigate to the config DHCP server policy instance:
<DEVICE>(config)#dhcp-server-policy <POLICY-NAME>
nx9500-6C8809(config)#dhcp-server-policy test nx9500-6C8809(config-dhcp-server-policy-test)#? DHCP policy Mode commands: bootp BOOTP specific configuration dhcp-class Configure DHCP class (for address allocation using DHCP user-class options) dhcp-pool Configure DHCP server address pool dhcp-server Activating dhcp server based on criteria no Negate a command or set its defaults option Define DHCP server option ping Specify ping parameters used by DHCP Server clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-dhcp-policy-test)#
Use the the following command to navigate to the config DHCPv6 server policy instance:
<DEVICE>(config)#dhcpv6-server-policy <POLICY-NAME>
nx9500-6C8809(config)#dhcpv6-server-policy test nx9500-6C8809(config-dhcpv6-server-policy-test)#? DHCPv6 server policy Mode commands: dhcpv6-pool Configure DHCPV6 server address pool no Negate a command or set its defaults option Define DHCPv6 server option restrict-vendor-options Restrict vendor specific options to be sent in server reply server-preference Server preference value sent in the reply, by the server to client clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-dhcpv6-server-policy-test)#
This chapter is organized into the following subsections:
